Corsair cx 430 power supply
Is this power supply http://www.amazon.co.uk/Corsair-Builder-Series-Bronze-Supply/dp/B009RMP14M/ref=sr_1_1?ie=UTF8&qid=1382561113&sr=8-1&keywords=cx+430
enough for an i5 3470 and a gtx 760?
http://www.amazon.co.uk/Intel-I5-3470-Processor-3-20GHZ-Socket/dp/B0083U94CO/ref=sr_1_1?ie=UTF8&qid=1382561096&sr=8-1&keywords=i5+3470
http://www.amazon.co.uk/Nvidia-GeForce-DirectCU-GDDR5-Graphics/dp/B00DM9B6FO/ref=sr_1_1?ie=UTF8&qid=1382561203&sr=8-1&keywords=gtx+760
I would recommend 500-550 watts
It would prob be enough but I would recommend going higher around 550W just to be safe and give you some extra wattage if you wanna add anything in the future.
get the cx600. the 430 only has 1 pcie connector.
see if you can get an xfx 550 watt or a seasonic but the cx 500 or cx 600 will be good too
