does corsair h110 and swiftec 220 fit in carbide 500r? thanks
The H110 should fit. The Swifttech is discontinued.
Where are you looking to place the cooler? Only option seems to be the side panel unless you remove the 2 bottom drive bays then you might be able to squeeze the swiftec in there. Doubt you can get the corsair in there tho cause its 140mm wide not 120mm like the swiftech.
"...room for a full 240mm radiator for compatibility" - Newegg says.
My bad i looked at the specs of the h110 so yea the corsair is fine also im not sure if the swiftech is discontinued seems like everyone is just sold out.
