It may sound stupid but will the pump + reservoir combo work correctly when faceing sideways ?
Heres the combo http://www.xs-pc.com/water-pumps/x2o-750-dual-bayrespump-acrylic-v4
Thanks.
Thanks.
As long as no air gets in the pump, yes. Ive seen a few water cooling builds in the Air 540 that used a dual bay and pump combo, but you need to find the sweet spot to make sure it has an optimal amount of water as to not burn out the pump.
