im looking to upgrade my rear aio from my arctic freezer II 120
to either a
Bykski B-RD120-TK60 radiator copper 120mm (60mm thickness)
or a
Aquacomputer airplex radical 4/120, aluminum fins
would either fit in the rear slot of
my Corsair 275R Airflow ATX Mid Tower Case
currently my arctic is
mounted in the rear in a pull con-fig with a single noctua fan with some after market filter mesh
between the case an aio , both ways of config push or pull have no change in performance the pull is
easier to clean with a shopvac from the outside so thats th reason for pull config
