Has anyone here had any experience with the corsair 250D in terms of clearance.
I previously had a bitfenix prodigy but my DVD drive and GPU would not fit inside so I ended up taking the side panel off so my GPU fans didn't scrape against it.
So the main thing I want to know is if my MSI gtx 770 will fit inside the case without having the fans touch the side panel as I know the case supports its length but I am not sure about its width.
-Binary
