Correct network mask help
So I was wondering if anybody could help me out with this homework problem because it seems like a trick question because its only asking for one answer but there are two viable answers and I am guessing in a real world application it would depend what the client wants.
Which network mask should you place on a class c address to accommodate a user requirement of two sub networks with a maximum of 35 hosts on each network?
A. 255.255.255.192
B. 255.255.255.224
C.255.255.255.240(wrong)
D.255.255.255.248(wrong)
With answer choice A
it allows for 4 sub-networks and 64 hosts (62 valid hosts addresses)
With answer choice B
it allows for 8 sub-networks and 32 hosts (30 valid hosts addresses)
So I am guessing choice A is the right answer because although it goes over the maximum of 35 hosts it only goes 2 over the required sub-networks and if I go with choice B that's just to many subnetworks and a waste of addresses since only 2 sub-networks are required.
Perhaps I'm just over thinking things and sorry for so much info.
Ah yeah perhaps it was a typo thanks for your input
You would have to go with option A, you could then use a DHCP pool to then limit the available addresses and block the others that you do not wish to be used.
