I am looking to buy a test bench for quickly changing out testing and working on hardware. I was looking for opinions on which of these three would be good. The thermal take core P3 (standard pci slot mount not vertical), the HighSpeed PC Half-Deck Tech Station, and the Lian li PC-T60B.
Honestly, test benches are 100% worthless.
Find the cheapest piece of peg board, get yourself some screws, buy a bunch of Velcro strips and call it a day.
15 bucks at your local hardware store is all you need and in some cases a simple piece of peg board is easier to use than some of these 100 dollar + test benches.
if you want a good case try this, it is the one i am currently using.
if you take off the pannels, it can make for a good testbench
wait for it to go on sale tho
Don't that also have a removable motherboard tray? I think it does...
But I was thinking about haf xb as well...
@psycho_666
Yeah it does.
Just make sure that when you buy a PSU, that the PSU is not to long as when you do cable management or will be a pain
