Copying over "My Documents"?
So yeah, I'm running an SSD/HDD system - my OS on the SSD and my data on two HDDs. Now, my SSD was meant to be used only for my OS and essential programs (Steam/VLC/Fraps, stuff that I use), but recently it has gotten filled with rubbish. On my SSD, in "My Documents", there's about 20GB worth of stuff which I want copied over to another drive.
Can I just copy and paste?
I mean, I see things like "EA Games", the "My Games" folder, "Telltale Games" and "Ubisoft" - seemingly quite important things. Now, will the programs which require these documents function if I copy all this over to a new drive or will I have to reinstall everything? I mean, I wasn't given the option to install these documents anywhere else, so I don't know how they ended up there.
It's just a bit frustrating, that's all. I have a 128GB SSD with only 29.3GB free....hmmm.....surely the OS and my couple of programs aren't THAT bad....
Thank you very much in advance! :D
Regards,
Gavin.
One option is to move everything over that doesn't have to be where it is for your programs to function properly. This is the easiest way and will probably work fine for you. Most of these folders made by games aren't too big and just contain settings and save files and whatnot. Another option would be to create a junction pointing to a folder on another drive so you can continue using your My Documents folder as you have been, but without actually taking up space on the SSD.
The way this works is by moving the folder to its new location and then making a junction so that the folder functions to the OS as if it's in its original location while actually storing the files elsewhere. For example, if you wanted to move your My Documents folder to "D:\Documents" you'd go into your user folder and move the folder from there to the D: drive. Then you'd open up the command prompt (as admin) and type in the following:
mklink /j "C:\Users\Yourname\Documents" "D:\Documents"
So basically:
mklink /j "place folder was" "place folder is"
The quotation marks aren't really necessary unless there's a space in the folder location. I like to use junctions to move cache and scratch directories to a RAM disk.
Thanks man :) You seem to know exactly what you're talking about. I'll get right to it!
