Cooling
I am wondering what I should use for CPU cooling. I'm looking into getting an H60 to cool an I5-2500k(going to overclock and run bf3 and fraps). Should I get a fan/heatsink instead?
Another side question... should I get an adata 128gb ssd and a western digital 1tb hdd or just get the ssd. I will be using fraps and I will have several games. Also if you could find a cheaper solution please tell me.
Adata ssd and western digital hdd: $110 on newegg
from what ive heard an h60 wont do much better than a good air cooler, esspecialy for the price.
i would get the hdd then buy a smaller ssd to use as a cache
Thanks if you have any fan/heatsinks that would be good could you give my the name of it?
If you're going to be doing any kind of recording with FRAPS or anything else then get a 1 TB minimum HDD, especially if recording at 1080p. I've never used watercooling but from what I read when it comes to the H* lineup it's pretty much H100 or just get a decent air cooler. Linus explained this on one of his live streams about how cooling is about surface area and if your radiator is just a 140mm square with a fan on it then you're no further ahead than if you just got a heantsink/fan that would be equivalent in surface area.
Ok I'll check on getting one that is BIG
Ok I found 2 that seem like a good choice any thoughts?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835146011
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176
P.S. I'm trying to keep it at or below $60
not sure if theyre worth the money over this one
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
0:
Thankyou... If I were a woman I would kiss you right now
