Cooling suggestion
Ok, so i was wondering what would be better for cooling, I have an NZXT Phantom, so i have a 200mm fan on the side panel blowing directly onto the GPU and CPU area, now would it better to use it like that or to take the panel off altogether and use it as an open air system, which would allow more air in, but the airflow wouldn't be directed at all, but i'll be able to see everything inside!
Pictures would be great for this question, but my guess with the current context would be to stick with the fan. Do you have any additional fans in your case?
