Cooling in the PC-TU 100
Hi guys! I was looking to do a build almost identical to the Calugo, but my issue is heat. Is it possible to run a 120mm loop as an exhaust where the intake normally is and then cut some ventilation holes in the bottom for the GPU to breathe? Would this be at all efficient? If not what case would you recommend? Any thoughts on the Roswill U3-B?
