I want to know if its possible for me to cool my cpu (fx-9590) with something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
or some other air cooler similar, preferably with as little maitanance as possible
Here's my spec if needed: http://pcpartpicker.com/user/AerialDarkguy/saved/3DlK
(yes im aware link its missing a cooler, i took it out while im trying to replace it)
then the best you would have to get is a NH-D14 or an NH-D15 by Noctua, they are the best CPU coolers that you can get that have equal or better performance than some water coolers.
