I've been looking into making a new build and one question I came up with is that do you necessarily need liquid cooling for a AMD FX9590 processor or does a good air cooling solution work fine for it? I may or may not do overclocking so you can also tell me the option for that.
You can get away with Aircooling if you Grab the Noctua NH-D14 or NH-D15 those are Air Coolers that Rival Watercoolers in terms of Temperature, Also they are a bit cheaper.
