Cooling for fx 6300
Hey guys,
does anyone have any ideas for cooling my fx 6300 as i want a cooler that will fit in a micro ATX case so isnt overly big and is also relatively cheap, e.g. 20-30 pounds
Responses appreciated!
Thanks.
look at one of this one http://www.newegg.com/Product/Product.aspx?Item=N82E16835608042 it might fit and what are the dimensions of your case.
What case do you have?
and are you interested in over clocking? How far?
The hyper 212evo is a pretty good solution for getting past the stock cooler.
the dark knight II is a step up from that. It does a really good on my 4.7Ghz FX6350
and just about anything from noctua is going to be top of the line
Probably a safe overclock, nothing too adventurous as it will be my first time so I want to test the water, so to say. Case is coolermaster silencio 352 mATX, dimensions 200 x 378 x 453 (WxHxD mm)
Thanks
Also thought the Hyper 212 EVO was AM3 only, not AM3+ otherwise would probs go for that
doesn't matter, the sockets are the same pardon a few pins i believe.
someone please correct me If i am wrong.
thank you for the help anyway! thanks guys
