Cooling for an 8700k CPU
I am debating getting an 8700k as my next CPU. Many people have said that you “need” water-cooling in order for it not to throttle. I have had good fortune over the years with my Hyper 212EVO on an i5-3570k. I am trying to sort through all of the AIO vs custom loop pros and cons. Any experience with an 8700k and what is needed to keep it running cool and not throttle. I wouldnt be trying to overclock any past 4.5 GHz, if even that high.
Intel specs the 8700k at 95W TDP. So anything better than that should work.
I can´t find official numbers concerning the cooling capacity of the 212 evo, but I will suffice until you decide on big air cooler or AIO.
AIOs have one important difference: The pump is your single point of failure. Swapping a case fan to an air cooler will get you over the weekend, but a dead pump will stop you dead in the tracks.
No experience with the 8700k but my 7700k runs pretty warm even with an aio. Not throttling but definitely warmer than I’d like to see it. Part of that though was shitty auto voltage applied by my board. You might see the same problem with modern boards. If you tune the voltage you might be ok stock with that cooler. I wouldn’t push it too far though.
If you wanted to stick with air cooling I would recommend the noctua nh d15 if you can fit it.
My 8700K is delidded so I won’t talk about or post therms with that CPU. Also, there are a lot of factors that come into play beside the cooling solution chosen for the CPU that make comparing your system to another’s not an apple to apple comparison. So getting back to your question and with the information you have provided about your intentions regarding over clocking and what’s necessary to prevent CPU throttling.
A full fledged open loop is not necessary - unless you just want one and are prepared for the added cost and maintenance. Regarding Air cooling for the 8700K, both Noctua NH D15 or Bequiet Dark Rock pro 4 are great tower coolers and will keep the 8700K under control even with a mild to decent over clock. For an AIO a minimum of a 280mm like Corsair H115i or Evga CLC 280.
Whether air or AIO - Consider your chassis first. What are its characteristics not just airflow but also can it support a tower cooler, What radiator mounting options does it have etc. ? What about options for additional intake/exhaust fans etc. and then match the cooling solution to your chassis. What about the mother board you have selected Does it have huge vrm heat-sinks or a larger I/O cover that could interfere with cooler mounting. How about your ram modules, Are they tall? how many modules do you have and could the cooler mounting solution interfere there as well?
Air coolers can be a little more of a pain to initially install and you need to be a little more mindful of things like RAM module clearances etc. but after that they don’t really go bad - a fan may go but easy to replace. AIOs generally really easy/quick to setup but do have a dependency on the pump which can go bad and not as easy to fix as popping on a new fan - you’ll have to get a new AIO or RMA the one you have; AKA extended system downtime potential is greater. However most all of the reputable AIO’s now have 5 year warranties and the failure rates are low.
I will say this. You may think you will never overclock your system beyond X or maybe Y but, I would be willing to bet that if you find your CPU is more of a gem than a rock and your system allows for a better overclock say 4.8 to 5.0GHz - You will do it. Any of the solutions proposed herein will allow for you to have some headroom thermally to do that. Not knocking the hyper 212 Evo it is a solid cooler and inexpensive but, I feel it is a bit out classed by an 8700K. That 95w TDP :slight_smile: mmm I dunno where they pulled that from…
First off, I would like to thank you for your very detailed response! Hearing that AIOs are decreasing their failure rate of the years is good news to hear. I have started to research the H115 skew of coolers as well as the NZXT Kraken x62. Currently the case I have is a Rosewill Thor v2, however I have been debating getting a Fractal R6 but have not yet made a final determination and will not until a cooler has been determined. Generally I prefer functionality over appearance and am not certain a new case is warranted. In the years of having my 3570K I have never overclocked it, likely because when I purchased it in 2012/13 I was not near as knowledgeable as now, and very well may OC a new 8700k.
I am also thinking that althought the Noctua air coolers are great, I would rather spend a few dollars more and get an AIO if it may offer a small thermal improvement. The motherboard I likely will be getting is the asus prime z370, which I forsee no cooler interference with.
With that being said, I have heard fairly little about the H115. Do you have any personal experience with it or know of many positive reviews?
Check out Gamers Nexus. They have a ton of data on cooler performance, both air and aio. I’m on my phone right now but when I get to work I’ll post some stuff.
EDIT: heres some stuff for you to bake on
I thought GN had done the NH D15 but I cant for the life of me find it. I did find the U14 though which should be very close in performance.
Experience with the H115i, yes. I have two older builds using the Corsair H115i - Both are cooling 7700Ks with 4.8 and 5.0 (not delidded) o-clocks and doing well. I did replace the included fans with corsair ML Pros which made them a bit more quiet than stock - though the stock ones were not overly loud. Looks like Adubs posted some good links for you to check out so not much sense in me blabbin on just to see it in print. I will add - that JayzTwoCents just posted a vid on Air cooling you might like to add to your list of check outs.
Which ever way you decide, I’m looking forward to hearing how it turned out and seeing pics of your completed build in the ‘Build logs’ or ‘Build a PC’ discussions.
