Hi there, I am looking at buying a new notebook/laptop. The ones Im looking at are said to run quite hot when under heavy load. I will be gaming on it and so this will put it under that heavy load. I was wondering if anyone had ideas to cool it?Just some system or method that would reduce the heat. I know people would recommend that I just build a desktop but due to circumstances I need a laptop.
I open to any ideas, even the really weird and whacky ones.
(or make a metal pad yourself with the fans just where they need to be)
If nothing else works then try modding forums for help on how to add more mass to the heatsink so it will cool better. But this is only if you really need it cool, and the laptop will probably become obsolete before failing you.
Thanks very much for the advice. Can you apply thermal paste to any surface? Eg: to internal sides to desprise heat. And can you please explain what a thermal pad is? I am unfamilier with this.
