So I just discovered I'm getting a Coolermaster X6 CPU cooler for christmas and was wondering if anyone has any opinions on it? Not that I can change the fact that I'm getting it (with me not supposed to actually know yet.) and I mean anything is better than the stock cooler... From reviews, It seems to be pretty decent, but I was wondering if any of you guys might have something to say about it?
Oh wow. I forgot that cooler even existed. I'm not sure how it performs, but it looks pretty badass. I would suggest looking up some reviews for performance results.
A unique angled base assists in compatibility and improving overall airflow within a chassis. Six heat pipes and a honeycomb fin structure assist in dissipating heat quickly to keep CPUs cool under high loads. A 120 mm sleeve bearing fan for long life. Looks good to me but again, looks are not everything. Check out some sites that will give some true performance reviews. Everything depends on the set up it is intended to cool.
