Hey guys,
I am in the market for a closed loop liquid CPU cooler for my rig. As stated in the title I have the Corsair 600T white case, so I am looking for a 240mm rad set up that will fit my case. I also have a ASUS Maximus VI Hero mobo if that information is pertinent. Thanks for the help guys and I hope that I gave you enough info to go off of.
Much obliged,
If an XSPC RS240 can fit in the roof then the CM AIO cooler should fit. Be aware that you will have to run the fans in a pull config under the outer top mesh.
If you have trouble, that top panel is very mod friendly. Meaning with a few drilled holes the 280 AIO's would be an option.
Not sure if that aio fits, but I konw that I'm not interested in modding my case, at least at this point in time. Do you know for sure that the CM cooler will fit?
There is no reason why it wouldnt. The 240L is 269mm x 127mm x 29mm, the H100 radiator is 275mm x 122mm x 27mm.
The 240L is pretty much a rebadged swiftech 220 aio. Therefore it will fit.
Proof it'll fit> http://www.overclock.net/t/1392968/corsair-600t-and-h220-expansion-watercooling-loop, http://linustechtips.com/main/topic/45560-how-can-i-mount-a-swiftech-h220-in-a-600t-and-still-be-able-to-add-liquid-when-i-have-the-mount-the-hole-upside-down/
Thanks, I was, and still am, somewhat worried about the cpu power connector and the two fan headers that are on the top of the mobo but I guess that they will be fine. Measuring clearances in a case with crap installed is hard...One more question, do you recommend a different cooler? This will be my first aio and I am just poking around for information.
Thanks,
