Cooler Question
I have an NZXT M59 case and i am wondering if the Cooler Master Hyper 212 EVO will fit?
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146058
Cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&nm_mc=BAC-Criteo&cm_mmc=BAC-Criteo-_-CPU+Cooling-_-Cooler+Master-_-35103099
Must I help again? Lol. According to NZXT the clearance for a cpu cooler is " CPU 141.0mm (with fan) 166.0mm (without fan) " the hyper 212 evo is 158.5mm tall, so it will fit with no fan on the side panel! Hope that helps.
Thanks Again! I did check those specs earlier but I wanted to make sure I was interpreting them correctly.
No problem, happy building!
