</p>
We check out another silent case, this one from Cooler Master. Check out the video for all the details.
Where to buy: http://amzn.to/1CRMUVp
Specs:
Model Number
SIL-652-KKN2
Available Color
Midnight Black
Materials
Polymer, Steel
Dimensions (W x H x D)
220 x 507 x 508.6 mm / 8.7 x 20 x 20 inch
Net Weight
10.4 kg / 22.9 lbs
M/B Type
microATX, ATX
5.25" Drive Bays
3 (exposed)
3.5" Drive Bays
9 (hidden; 7 in the HDD/SSD combo cage, 1 at the bottom, 1 in the ODD cage by adapter)
2.5" Drive Bays
10 (hidden; 7 in the HDD/SSD combo cages, 1 under the ODD cage, 1 behind the M/B tray,1 at the bottom)
I/O Panel
USB 3.0 x 2, USB 2.0 x 2, Audio x 1 (supports AC97 / HD Audio), Mic x 1, SD card reader (Class 10) x 1
Expansion Slots
7+1
Cooling System
Top: 180/200mm fan x 1, or 120/140mm fan x 2 (optional)Front: 120mm Silencio FP 120 fan x 2 (installed; 11±1 dBA, 1200±200 RPM)Rear: 120mm Silencio FP 120 fan x 1 (installed; 11±1 dBA, 1200±200 RPM)Side: 180/200mm fan x 1 (optional)Bottom: 120/180mm fan x 1 (optional)HDD cage: 120mm fan x 1 (optional)
Power Supply Type
Standard ATX PS2
Maximum Compatibility
VGA card length: 423 mm / 16.6 inchCPU cooler height: 168mm / 6.6 inch
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/cooler-master-silencio-652s-silent-case-overview
