Cooler Master PSUs
Are Cooler Master PSUs bad or can tehy be used, i am thinking about buying a CX 650W since it was cheap, but i have heard that the PSU i something one shouldnt skimp out on but are these okay?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171052&nm_mc=AFC-C8Junction&cm_sp=&AID=10446076&PID=3938566&SID=
As long as it's bronze certified, and large enough for your system, you should be fine.
Cooler Master are one of the companies that actually manufacturer high quality PSUs. Again, as just stated, insure it is minimum 80+bronze certified because it guarantees a specific voltage going to your components.  Here is a page from Cooler Master explaining some of the innovations they use in their high end PSUs.
http://www.coolermaster-usa.com/product.php?product_id=10006&product_name=Silent%20Pro%20Platinum%201000W
Thanks, I just wanted to know if they were high quality, since i havnt seen them used that much. i saw a TTL review of the Thortech Thunderbolt 1200w, and he said that it was a really bad PSU, but it did have a 80+ cetification.
