http://www.newegg.com/Product/Product.aspx?Item=N82E16817171060&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Opinions?
My estimated watage is 364w. (According to PCPartPicker)
EDIT- My build-- http://pcpartpicker.com/user/TrivTrav/saved/1Fpa
I've heard dodgy things about Cooler Master PSU's.
For that price, I'd rather get a CX500M from Corsair for around $40. Atleast Corsair is a brand everyone can trust.
TrivTrav, we built you a system ages ago. You still trying to save money on that thing?
It is advisable to go with a 500-550W supply. It will accommodate the larger cards you will want to upgrade to. Pick a PSU with a good OEM, like XFX. Their OEM is Seasonic, and XFX is cheap. Get a supply that has a good rated efficiency.
best psu on a budget is the xfx 450w its like $50 and it works great I put one in a freinds computer and it handles his overclocked fx6300 and overclocked hd7770 with out even reving up the fan under load. Not to mention its a seasonic which is great
I'm not quite sure the CM PSUs deserve the bad press they get - I originally wanted a Corsair 650 but my local store was out of them, so on an impatient whim I bought a GX650. I've had it for about 4 years and over two builds, it's never missed a beat. And it was cheap.
