Hey i just installed my CM hyper 212 EVO, And i couldnt fit the push configuration because of my RAM. So is it viable to use pull configuration?:)
Yep, your temps will be around the same too!
Great, I also have a fan that pushes air towards the Heatsink.:)
I don’t know if this will affect you directly but this video is well worth the watch when it comes to airflow through a radiator. Hope it helps.
https://www.youtube.com/watch?v=UyC3lZ5WFMk
