just a heads up on a problem i ran into with the cooler master h.a.f stacker 935 case.
if said person wants to put the power supply in the main body and not the itx case, just be careful of clearance
issues. as the back wall has indents that protrude into the body of the case which can cause clearance issues
with a larger power supply i.e ''evga supernova g2 1300watt''.
the issue being that it causes the screw holes to be a couple mm off due to the indents.
fix for this would be to angle grind/ dremel cut the indents.
http://www.coolermaster.com/images/upload/images/case/935-airflow.jpg
