My son has a fascination with small form factor cases. I’m obsessed with cable management and aesthetics. This is what happened when he asked me to “clean up” his cabling: a heavily modded Elite 130 case. Hope you enjoy, and any feedback is welcome!
You did all of that yourself?
That’s amazing.
Thank you!
I cut the window in the case, made the GPU backplate and the acrylic panel in the bottom (covered the SATA and USB 30 cables,) and made and sleeved all the wiring. Also removed the drive bay to allow room for the AIO radiator and fans up front.
I actually redid that backplate, the original one ended up with some scratches on it. Should have redone that photo…but I’m a modder, not a photographer!
That is some damn fine work
Thank you! Looking forward to my next mod - just need to find someone in need, lol.
My gears are solid
