Convert HTPC into gaming rig + steamOS considerations
Help / advice requested.
I'm going to finally have a little bit of scratch to blow on something for xmas for myself.  about $300 or so ... I'm really stoked about SteamOS and all the greatness that I hope that becomes.  I would really like SteamOS to be my HTPC with main duties of being an HTPC via XBMC while also obviously being my main gaming interface.  I have a family and no room for a true dedicated gaming machine.  I'll be gaming from my couch with HOPEFULLY a Steam controller that truly allows a decent interface for playing all PC games from said couch.  Whether or not that pans out is not the discussion topic here.  Lets just assume that SteamOS is going to be amazing, the controller is going to be amazing, and the game streaming from Windows to SteamOS is going to be amazing.  There.  Thats the world i'm discussing here.  Thats the world that applies here.
I want to upgrade my current HTPC outlined here:
http://pcpartpicker.com/user/dustinarden/saved/QHV
That list excludes my storage, which consists of a 90GB SSD for Win7 OS and several TB's of storage for games and media etc.  I dont know what my current PSU is to be honest.  I dont want to disconnect everything and look at it while writing this post (watching tv).  So I might have to get another PSU, but I dont think I will.  If i have to get a new one for the upgrade or soon after i'll snatch the one mentioned in the latest $650 build video.
These are the components that I want to snatch to upgrade my current HTPC to play games of this generation and next (battlefield 4, and games that come out next year etc)
http://pcpartpicker.com/user/dustinarden/saved/37Be
I have another case already that will actually fit this mobo and gfx card etc.  The HTPC case in the first link will get packed away for a while most likely ...
What I want to do is take the memory, storage and tv tuner card out of my current HTPC case and put it into the old full size case along with the above components.  That would now be my HTPC.  The form factor would suck for that cause but I would hope it would only be temporary.
My long term goals depending on when the SteamOS gets fully implemented and rolled out / patched and updated etc is this.
Have a HTPC comparable to what I have currently as my HTPC (most likely the same parts).  It will be a low power system that can handle XBMC etc.  Since a lot of the games I want to play and will want to play via steam most likely wont support linux for years to come i'm going to need the gaming rig to keep windows 7 as the base OS and then stream to the lower power actual HTPC.  That way I can turn it off and on as needed for gaming to keep power consumption and heat down.
Does what I'm trying to do make sense?  Should I pick different parts?  Keep in mind my budget right now is about 300 but I can spend a little more ... so its most likely closer to 400.  That should allow me to get a new MoBol, CPU, and the R9 270X which I'm assuming will have pretty decent future proofing ... My HTPC will be overkill for a while as its mainly a gaming PC at that point, but in a few months I can buy a new SSD and some memory for the older HTPC and then slap SteamOS on there (after i've toyed around with it on laptops and as a dual boot perhaps with the gaming machine) so that its my main HTPC that only relies on the beefier system when its needed for streaming games not natively supported by linux or that need the extra horsepower.
I think my logic is decently sound there... just curious about other parts that may make more sense or have a better price to performance ratio.
Thanks.
Currently I run a media PC in the form of an Intel NUC with OpenELEC. Even that should be capable of streaming SteamOS and playing the less demanding games natively with the Intel 4000 integrated chip. I use an external 2.5" 1TB drive for media and just use a wii-mote to control it. That will be my Steambox to start!
As for the build, if your in need of a case and PSU anyway to cope (I'm not sure if you are) with a discreet card, consider a simple EVGA Hadron build. Although that may be £150 ontop of your budget if I'm jumping the gun... But if your PC is going to be next to the TV in the lounge, you don't really want a full-sized tower. :D
My choice, although this is my preference without knowing your full situation...
Buy an EVGA Hadron Air, a Haswell Core i5S (low power version, but up to you!) and the cheapest Mini-ITX 1150 board money can buy. From Overclockers that is currently £400 if you include VAT. You may be able to scrimp with sales/other sites here and there or even drop right down to a i3 or pentium if you so wish. Transfer one 4GB stick of memory from your HTPC, some form of storage and you'll have a fully working little beast... and a fully working HTPC.
Later down the line, say nearer the time SteamOS will actually surface, transfer the remaining 4GB stick to the new PC and replace with bargain bin 4GB set and buy whatever the best GPU you can get for £150-200.
Benefits include a properly future-proofed i5/Haswell machine, much lower power consumption, very small spacial footprint, keeping your current HTPC as a working HTPC.
Downsides is you'll be without gaming-grade graphics card until you can pluck up the money in a few months or so. Integrated graphics will still cope with most of the indie games and loads of older games, just not big graphical AAAs from the last couple years.
What is your opinion on that sort of approach?
Final note, look into OpenELEC for your HTPC. It makes media PC's super easy and really low requirement.
