I have these two monitors now Gateway FHX2402L with these specs:
Display 24-inch widescreen LCD
Active Display Area 20.92 × 11.76 inches (531.30 × 298.80 mm)
Maximum Resolution 1920 × 1080
Maximum Refresh Rate 60 Hz
Response Time 2 ms
Contrast Ratio Dynamic: 12,000,000:1
Brightness 250 cd/m2
Viewing Angles Horizonal: 176°Vertical: 176°
Number of Colors 16.7 million
Inputs One VGA port One HDMI port with HDCP One DVI port
I want to add a third but I can't find it anywhere. This model I think is discontinued.If anyone can find that exact same monitor I will make mad passionate love with you.
The closest one I could find is this model:
http://ca.pcpartpicker.com/part/asus-monitor-ve248h
The contrast is 2 million less than the gateway but it has the exact same brightness. Wondering if I'm going to notice a difference like that?
