Ive noticed this, I dont know if this is common or something but on my laptop (Lenovo T440S) running Arch and on my main rig (running both Win7 and Arch) when I watch anime (I dont know about other multimedia because I only really watch anime) I get ridiculous screen tearing, especially during action scenes. Should I be doing something with the refresh rate of my monitors (laptop built in display, desktop 3 Benq 1080p displays over DVI I cant remember the name of)
This happens both if I download media and use VLC or if I watch on sites as Kissanime.
Should I just suck it up?
What is it like with a simple youtube video?
I will check now and get back to you
Even a simple video like this:
clips in the opening scene
sajkowolfe:
Lenovo T440S
Well if it is on both your laptop AND desktop, and it happens on two different OSes, then IDK what to tell you.
Try downloading the video or try a different browser? Maybe your internet packages are just getting messed up?
It happens on multiple network connections....
Im not sure if Im just being sensitive? Or I somehow fuck up all my devices? :D
Doesnt happen on my mobile though.
See on any linux distro, screen tearing is a normal issue. But on windows 7 too?
Is the screen tearing on windows 7 any different from arch? Are you sure both your screens are at 60hz?
This HAS to be something simple.
Depending on your hardware (mainly GPU) and DE (desktop enviroment), you could be able to fix it.
Ive never checked to be honest, I dont even know if my laptop panel refresh rate can be modified (well never mind everything can be modified)...
@spidernet my laptop has an intel integrated and my desktop has a GTX 760
Openbox on my laptop and whatever Trisqel uses on my desktop (and Windows 7 too)
OpenBox is one of the worst when it comes to screen tearing (and I use it). For your laptop try https://wiki.archlinux.org/index.php/Intel_graphics#Tear-free_video or you can try using compton https://wiki.archlinux.org/index.php/Compton
"Error when reading configuration file "/home/wolfela/.config/compton.conf", line 16: duplicate setting name Another composite manager is already running"
Love it when my box runs something I wasnt expecting.
you have another composite manager running. Disable the other first.
I gathered that, I just dont know what one or how to check
[wolfela@eofe ~]$ env XDG_VTNR=7 XDG_SESSION_ID=c1 XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/wolfela SHELL=/bin/bash TERM=xterm GTK_MODULES=canberra-gtk-module USER=wolfela XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0 XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0 MOZ_PLUGIN_PATH=/usr/lib/mozilla/plugins PATH=/usr/local/sbin:/usr/local/bin:/usr/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl DESKTOP_SESSION=openbox MAIL=/var/spool/mail/wolfela LC_COLLATE=en_GB.UTF-8 PWD=/home/wolfela XDG_SESSION_TYPE=x11 EDITOR=/usr/bin/nano LANG=en_GB.UTF-8 GDMSESSION=openbox SHLVL=1 XDG_SEAT=seat0 HOME=/home/wolfela LOGNAME=wolfela XDG_SESSION_DESKTOP=openbox DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus BROWSER=/usr/bin/chromium DISPLAY=:0 XDG_RUNTIME_DIR=/run/user/1000 XAUTHORITY=/home/wolfela/.Xauthority _=/usr/bin/env
Im assuming its one of these values?
openbox alone doesn't provide compositing, so you probably installed one of these before:https://wiki.archlinux.org/index.php/Xorg#Composite
Oki, I already have compton!
:D eheh Is it correctly configured? Do you have the TearFree option in your xorg.conf? For an example of a compton.conf look here: http://ubuntuforums.org/showthread.php?t=2144468&p=12644745#post12644745
Grog
January 5, 2016, 4:02pm
19
As y'all seem to both be having issues with VLC and Linux, I thought I would link both threads. https://forum.teksyndicate.com/t/vlc-slow-performance/94603
My problem is very different to that one though?
Grog
January 5, 2016, 4:26pm
21
Okay sorry, just thought it may help.
