Hi people of the tek world once again, I almost have enough money for building another pc (the one now is pretty crappy) and have decided to put a little extra money to keep it well lasting. My budget is around 1200$, and when i daydream about a pc, i usually go for 800. So this pc is gonna be something that will last 4 years without switching ANYTHING and will play games on ultra 1080p for a Year and Med-High 4+ Years. Note though that this pc was meant so that I will upgrade it when the consoles get a refresh. that also means that this is a console killer build. sorry for the long intro. This is the build so far: http://pcpartpicker.com/p/2kIji
QUESTIONS:
i didn't choose a case since I wanted to use the colossus m-atx which hasn't been released yet.
I don't want to overclock too much, if at all, since it might lower the life span of my pc
i'm not sure if i should add more case fans for better ventaliation
is this build good?
Thanks for helping me out :D
EDIT: I wasn't sure if i was to go for a r9 290 since they seem to be 100+ dollars expensive when the aftermarket coolers come, and with the stock one it seems like it would burn out in a week.
DOUBLE EDIT: I'm getting this in about 3 months, possibly a little more, no more than 6 months.
TRIPLE EDIT: This is going to be a quiet pc.
QUADRUPLE EDIT: I live in the U.S., game at 1080p, and I will be also using this for everyday stuff like surfing the internet.
It is not possible to build a PC for a reasonable price that will play games released 4+ years from now on high. You'll be better off building a cheaper machine and saving up for upgrades down the line.
I think you're going to be perfectly fine with this build.
There's really no such thing as future-proofing a PC, as many will tell you. However, you can plan ahead by picking things you know will be compatible / still work later down the line. Picking up a good Motherboard, CPU, RAM, and grabbing a solid SSD and/or HDD are the essentials really. At some point you'll have to upgrade to a new GPU, but if your motherboard supports SLI you really shouldn't have to worry much.
A good friend of mine is running a 2500K and 2 560Ti's in SLI and is playing BF4 on med/high well above 60 fps. Mind you this is without over-clocking of any sort (the gain wouldn't be significant anyways). Just do your research, see how things are performing on newer games.
I built my newest PC about 5 days ago. It's running a 4770K and GTX 760 with a mild overclock and I'm running Assassin's Creed 4 on the max settings above 60fps (with vsync off), and that game is horribly optimized if I've been reading facts. These numbers might not mean much, but I'm just giving examples with newer games. Hope this helps a little. Good luck to you!
do i need a quiet fan for the h55 and the case to make it quieter? I think it would be cool if the pc would be really silent and stuff with all the multi colored lazer beam on the colossus m.
I would definitely up the wattage on your PSU if you're going to run Crossfire/SLI and overclock.
AMD cards usually require a little more wattage than Nvidia cards (I'm not sure how much); as an example - if I were to run 2 760s in SLI it's recommended that I have ~700 watts. You can probably find a good 750 watt Corsair psu for a fair price. I'd recommend looking at the TX series if you want to save some money, but still have a solid PSU. 750 watts should prevent you from having to upgrade down the road, however you may want to check the recommended wattage for Crossfire/SLI on the card's manufacturer website.
Sorry I didn't mention this earlier. I totally missed the PSU in your partpicker list; my mistake!
