Hi,i never saw anyone do this on YouTube and Logan says the people on build a PC are great,So i need a system for around £300-£350 pounds (GB),I want to get into PC gaming because im just tired of consoles.Any help would be appreciated Thanks for your time!
For around £300. It'll play any given game at a reasonable setting, usually at 1080p.
http://uk.pcpartpicker.com/p/1Imft
At this price point, the marginal cost benefit is quite high. If you were to spend an additional £10, you could increase your storage capacity 100%.
The additional budget should be invested in the video card:
http://uk.pcpartpicker.com/p/1IRIv
It'll give you much more performance. Only problem is, in games that are a little CPU intensive, you'll probably have to turn down settings. In most games you could probably play on medium/high.
Similar capability, but many more upgrade paths:
http://uk.pcpartpicker.com/p/1IROw
e.g higher end graphics cards. Maybe a 83xx CPU.
