Coming over to the dark side from consoles( budget gaming rig build help)
Well after watching the new console reveals, I stumbled upon some of the tek videos on youtube...then marathon the whole series,and decided to build a gaming PC. My budget is ~$450 I did as much research as i could watching videos, reading reviews and this is what i came up with. Any help going over these parts would be greatly appreciated. My goal is to play FPS and games in general with the quality of current gen graphics.
Thanks for the help
http://pcpartpicker.com/p/11XUt
i would remove that radimax not an well known brand for power suppiles go with an Corsair CX series they cost more but a bad power supply can take out a lot of your other hardware motherboard, GPU, HDD ect
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
Didn't know it was a bad brand,Thanks I'll go with one of these corsair.
Do you need an hdd. keyboard, mouse or anything?
No i got a Spare 500gb and will use my mouse and keyboard from my old computer :)
This would be a good psu that should not burn your house down :) http://pcpartpicker.com/p/8cN
