Console Gamer going PC! - #2
My pc case is finally here and it looks EPIC!
But anyways I'm like 1/6 away from done and I will like to thank anarmypig for helping me with the components and All the support I can't wait for this PC to be finished.
But in the mean time , what games should I get (Free/Paid) and is there any good cheap monitors because they seem pretty expensive.
What I Have/Don't Have:
Keyboard ☑
Mouse ☑
Monitor ☒
Case ☑
MotherBoard ☒
Headphones ☑
GPU ☒
CPU ☒
RAM ☒
Power Supply ☒
Optical Drive ☒
 Pc Pic's: http://imgur.com/a/xOlro#0
what are your specs?
http://pcpartpicker.com/p/JTv5
A monitor is only like 140$, that's not even remotely expensive!
It is when you broke :P
nooo bad buyzz.. get a a6 3670k.. ther faster than that phenom (when oced to same speed) and have built in grphics that could support your graphics card and  make the whole system faster by saving 3 dollars! And they even have an open multiplier so any fm1 motherboard can oc it! Get a seagate hdd.. they last longer.. infact not a single seagate ive ever bought has died and their cheaper while a shitton of my wd's have.... buy a 50 dollar gigabyte board and it will outlast that shitty asus one..
but ultimately i suggest this for saving $92  http://pcpartpicker.com/p/LWa5
Make sure the first thing you do is install steam. Games are hella cheap there, especially if you wait for a sale.
Dont get an APU unless you want crap performance. I had the latest A10 and it bottlenecked my cards(crossfire 2gb 7850's) . Get a good CPU and Mobo first. A good GPU and faster Ram can wait.... If anything get a used GPU, they are ussually good used and will save you lots of money if this is your first build. Also the PSU is very very important. I myself through experiance cant tell you that it is a part you do not want to cheap out on.
