Currently i am running a GTX 650 Ti Boost, i have it BIOS modded with my overclock (when i 1st overclocked it there was no OC support on the linux drivers so a bios mod was the only way)
Anyway I get sustained boost clocks of 1184 to 1215 Mhz, usually holds 1215Mhz
Are there any thing things that are known to not work in linux (xubuntu 18.04) on the RX 570
by which i mean bugs/glitches/crashes
I know AMD has been going open source with there drivers, linux driver support is the reason i have been using nvidia cards, but if AMD’s linux drivers are up to par i may as well get away form proprietary nvidia drivers
There is one feature category thing i was wondering, a lot of cards have RGB stuff i do not care about, can i turn this off or add just the pwm frequency to make the flashy lights dim accent lights
I was looking as the Asus ROG Strix version, as the design looks to have good support to prevent card sag
