ConnectPro KVM (UDP-12AP): long time to connect and low resolution + Hz
I just got a used ConnectPro UDP-12AP, it looks like its in good condition with no broken port pins from quick inspection. I tried connecting both my mac and pc to it (the mac using a USB-C to DP adapter). After connecting either one to port 2 and pressing the reset button, it takes awhile for the display to show up, and its only 1080p60.
My monitor is an MSI 321URX (4k 240hz), I get full resolution & Hz to the monitor, and a Startech KVM (p2cdd143) (both with DSC). The product page says its supports DSC, but I notice that after I connect both my monitor and either computer to the KVM, the DSC setting gets turned off on my monitor. After I turn on DSC while they’re connected and press the reset button,
I did some searching for how to install firmware and didn’t find anything, except sentences here and there on multiple website pages stating that it can be updated and using a serial cable, but how do I download it and initiate installation? I emailed their support email.
I finally figured out how to use it, I have to connect all the USB and DP cables, then press reset to make the devices properly initializes, then it works properly.
