Connectivity monitor to reconnect vpn
hello, im running a windows pc that has a vpn connection but sometimes the connection drops. i have another similar linux system that uses a script that pings the connection to google and if it doesnt get a successful ping, it reconnects. can this be done with windows using something basic? i have looked online but cant really find anything but do find more for linux.
Windows isn't much of a scripting language, theres probably a command line solution, but otherwise you could  check this out: http://www.guavi.com/vpncheck_free.html
It is paid, but it shouldn't be too difficult to get ahold of it.
