Hello to everyone.
I’m trying to configure Barrier on the server and client side of the two OSes that I’m running because I want to use the same mouse and keyboard for both. This is what Ifconfig says on the server side :
root@ziomario-Z390-AORUS-PRO:/home/ziomario# ifconfig
anbox0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.250.1 netmask 255.255.255.0 broadcast 0.0.0.0
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.6 netmask 255.255.255.0 broadcast 192.168.1.255
tap0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500
inet6 fe80::d8f5:6dff:fef8:f194 prefixlen 64 scopeid 0x20
ether eb:f5:6d:f8:f1:94 txqueuelen 1000 (Ethernet)
virbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
virbr0-nic: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 63:54:00:6b:98:0e txqueuelen 1000 (Ethernet)
Instead,this is what Ifconfig says on the client side :
en0 = 192.168.122.63
utun0 = no IP
utun1 = no IP
On the client side,on the barrier panel I selected “client”. Screen name = pc-di-mario.local. Server IP = 192.168.1.6. But I tried also : 192.168.122.1 and 192.168.22.63
On the server side,on the barrier panel I selected “server”. IP = “192.168.1.6”
Nothing worked .
This is the log of barrier on the server side :
[2019-10-28T15:17:47] INFO: accepted secure socket
[2019-10-28T15:17:47] INFO: ECDHE-RSA-AES256-GCM-SHA384 TLSv1.2 Kx=ECDH Au=RSA Enc=AESGCM(256) Mac=AEAD
[2019-10-28T15:17:47] NOTE: accepted client connection
[2019-10-28T15:17:47] NOTE: disconnecting client “pc-di-mario.local”
[2019-10-28T15:17:47] WARNING: unrecognised client name “pc-di-mario.local”, check server config
[2019-10-28T15:17:47] NOTE: client “pc-di-mario.local” has disconnected
[2019-10-28T15:17:48] INFO: OpenSSL 1.1.1b 26 Feb 2019
[2019-10-28T15:17:48] ERROR: ssl error occurred (system call failure)
[2019-10-28T15:17:48] ERROR: failed to accept secure socket
[2019-10-28T15:17:48] INFO: client connection may not be secure
This is how I have configured the net for the guest OS with qemu :
sudo ip tuntap add dev tap0 mode tap
sudo ip link set tap0 up promisc on
sudo ip link set dev virbr0 up
sudo brctl addif virbr0 tap0
-netdev tap,id=net0,ifname=tap0,script=no,downscript=no -device e1000-82545em,netdev=net0,id=net0,mac=52:54:00:c9:18:27
