I have a big ethernet cable but wouldnt like to put wholes in my walls to run it to the router.Is their a wireless adapter or something they make for a pc? HELPPPP
there's pci wireless cards you can buy... http://www.outletpc.com/fj1868.html?utm_source=fj1868&utm_medium=shopping%2Bengine&utm_campaign=pcpartpicker&utm_content=Asus%2B-%2BNetworking%20%3E%20Network%20Cards%20-%20Wireless
something like that should do fine...
Do they specify with build? Here's my rig just in case
http://pcpartpicker.com/p/35Fmn
http://www.amazon.com/TP-LINK-TL-WDN4800-Wireless-Express-Low-profile/dp/B007GMPZ0A/ref=sr_1_3?ie=UTF8&qid=1394635259&sr=8-3&keywords=Asus+PCE-N10+PCIe+x1+150Mbps+Wireless-N+Network+Adapter Would do yall think about this?
Any PCI-E would work, including the one you linked and the one DrunkenPanda linked. Simply decide how much to spend, read some reviews and run with it.
Oh cool,Im just looking for one that'll give me the best connection to my network and last, Thanks guys!
Will this be compatible with my build I posted above? I really like this one and theirs ton of good reveiws about it http://www.amazon.com/Dual-Band-Wireless-AC1900-PCI-E-Adapter-PCE-AC68/dp/B00F42V83C/ref=sr_1_fkmr0_1?ie=UTF8&qid=1394635259&sr=8-1-fkmr0&keywords=Asus+PCE-N10+PCIe+x1+150Mbps+Wireless-N+Network+Adapter
Yeah that'll be just fine.
you can use a powerline adapter. they are getting cheaper by the day. look it up.
note to OP... if your router doesn't have AC networking... you're spending a significant amount of money on nothing... get a Netgear or TP Link (stay away from Buffalo) AC networking router if you're going to splurge on this, so, you know... you can use it... ;)
also note... AC networking doesn't have a large casting signal... I'd revisit this option if I were longer than 50 feet away from the original router...
... otherwise it's no better than that $15 card I posted to begin with...
