Hello, my PC sits in the living room with 30 ft between it and the TV. What is the best Best way to connect it to the TV so that I can set back and game? A long HDMI cable? My graphics card is HD5870 infinity version, so it has only display port and i gotta use a converter to connect it with hdmi.
Thanks
Wireless HDMI?
http://www.amazon.com/Actiontec-SBWD100KIT01-ScreenBeam-Wireless-Transmitter/dp/B009Z8T3K6/ref=sr_1_16?ie=UTF8&qid=1401225905&sr=8-16&keywords=wireless+hdmi
I did something similar. In my house there is a crawl space and the coaxial cable comes out of the floor. I have an Ethernet run similarly to my computer so all i had to do was widen the holes in the little cover thing. Not if sure if you have the same situation at your house but it seems like a wireless solution would have too much latency to game.
