My motherboard manual says I need to connect message/power/sleep led
Power led
Power switch
Speaker
Hard drive activity led
Reset switch
Chassis intrusion header
And my case has power led+
H.d.d led
Power led +
Reset sw
Power switch
Help please
Connect the cables from the case, they should be labeled. You don't need all those things, you just connect whichever ones your case has.
