Not really sure which topic to post this under...
Looking for the best solution to hook up 2 computers to one monitor via DVI. Doing a little research, sounds like DVI splitters are not a quality or reliable solution.
Any suggestions. Maybe a KVM switch? If so, can you recommend one?
Of course, I will only be using one computer at a time, but want to be able to utilize the same monitor without having to physically move cables around depending on the computer am using.
