We have an ESXi lab at work on a C Class private network. It’s completely isolated and on a stand alone domain with its own DC’s, SQL / file / WSUS / telephony servers and a pile of Linux boxes. The only way into that network is through a jump server. I use pfSense to isolate the Lab and only allow the single jump server static IP to access the internal Lab network. Then IT staff can RDP into the Lab from the jump server and experiment without anything touching Production.
Remmina should work for a Linux RDP solution. I use that to access Windows VM’s in my home lab from my Linux workstation. If on Win 11 then regular RDP should work, providing access is limited to that IP.
Interesting. I have this VM running Spice which I noticed Remmina supports. Would it then be possible to access just that over the VPN? That leaves the VM network entirely alone which would feel even better.
