Hello, Running a 3950X on a Gigabyte X570 Master. Trying to get lm_senors working with Ubuntu Mate 20.04 and a 5.9.9 Linux kernel. However I had this working on my Asus Prime Pro X570 with a 2700X Ubuntu Mate 20.04.
In checking previous threads it seems that the chipset for this mobo (ITE IT8792E Super IO Sensors) does print out information or the appropriate kernel modules are not available?? However I have 3 fan cases and I am not sure of the CPU temperature.
I do see the it87 module loaded, i compiled lm_sensors from source (github) but again not sure if this is accurate or the right configuration for my Motherboard.
Can some one here help with either pointing me to the correct code for the X570 motherboard or if I need to create a config file for my MOBO (github repo it87) or any other information would be appreciated.
Here is what my current version of lm_sensors outputs:
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +37.0°C
it8792-isa-0a60
Adapter: ISA adapter
in0: 1.78 V (min = +0.00 V, max = +2.78 V)
in1: 665.00 mV (min = +0.00 V, max = +2.78 V)
in2: 981.00 mV (min = +0.00 V, max = +2.78 V)
+3.3V: 3.31 V (min = +0.00 V, max = +5.56 V)
in4: 1.79 V (min = +0.00 V, max = +2.78 V)
in5: 1.17 V (min = +0.00 V, max = +2.78 V)
in6: 2.78 V (min = +0.00 V, max = +2.78 V) ALARM
3VSB: 3.29 V (min = +0.00 V, max = +5.56 V)
Vbat: 3.14 V
fan1: 0 RPM (min = 0 RPM)
fan2: 0 RPM (min = 0 RPM)
fan3: 660 RPM (min = 0 RPM)
temp1: +37.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp2: -55.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
temp3: +36.0°C (low = +127.0°C, high = +127.0°C) sensor = thermistor
intrusion0: ALARM
acpitz-acpi-0
Adapter: ACPI interface
temp1: +16.8°C (crit = +20.8°C)
k10temp-pci-00c3
Adapter: PCI adapter
Vcore: 1.37 V
Vsoc: 1.08 V
Tctl: +52.8°C
Tdie: +52.8°C
Tccd1: +43.8°C
Tccd2: +43.8°C
Icore: 27.00 A
Isoc: 8.50 A
nvme-pci-0100
Composite: +27.9°C (low = -0.1°C, high = +74.8°C)
(crit = +79.8°C)
