Hey community, I'd be interested to hear what you have to say in regards to recommending me a microphone. I plan to use this microphone for home recording in a mini sound booth I'm making, meaning that it should be a condenser microphone.
I've already got an SM58 (which is great for live) and an interface with Phantom power.
I plan to recording singing/screaming \m/ (think Killswitch Engage), voice acting and commentaries.
My budget is $100-$300 AUD and would appreciate good value for money, weighed against a microphone that will serve me well for years.
it's a very good mic, with a not too accentuated proxymity effect. I would stick with a cardiod, but if you'd like a more 'open' sound, an omni might be a better choice (but you'll need seriuos audio insulation). If so, I'd spalsh a bit for this
I know they're all in the upper limit of your budget, but any of the above choices will last you a lifetime and will be great to record with, although they might show the limitations of your interface preamps! It's the beginning of a very vicious circle!
Thanks dude for the in-depth reply, seriously. I will definitely buy one these and probably in the higher price bracket too. I might even be able to scab my brother's preamp for important recordings, thanks :D!
