Computer won't start unless a key is pressed
My computer is being a little weird, it won't start or show the splash screen of the motherboard on it's own but if I press any key it'll start up, this just started about a week ago. I was wondering if there's something I can do to fix this small problem, it's just bothers me a bit, since usually if would just all start up by it's self , ya know.
update bios? never heard of this problem before.
Are you in hibernation mode?
I suggest checking the BIOS settings for any kind of reference to Halt on xxxx as perhaps this is halting on a particular error that cropped up and obviously if your computer works fine there is no real issue. It could be as something as simple as a keyboard halting this process.
try defaulting your bios and see if it still happens.
