ok so to cut to the chase, when i turn on the system the fans will run ( case and cpu fan ) all LED's will turn on.
So there will be no signal to the monitor (GPU and cable is fine )
and My keyboard (USB ) wont turn on
Is this a faulty motherboard or PSU issue?
things I have tried:
resitting ram into a different slot and same slot,
ensured that all power connections are in.
PLEASE HELP!
Try to use the computer without a graphics card, if possible. Once, my computer wouldn't post because my graphics card was faulty. And I doubt its the power supple because the fans do run and the motherboard lights turn on.
As I have said, graphics card is fine.
It looks like a vital component is missing/not working. (RAM, CPU or motherboard problems)
But it seems you double-checked everything. All you can do now is swap out parts to another system and see which ones work and which dont...
Due to the CPU fan running I think it's ok , resitted ram multiple times.
Motherboard it is?
Do you know much about CMOS?
Have you made sure the atx &12v power connector are both in? This is what happened to me before
Yea I unplugged and plugged them back in.
