I’m trying to fix a problem with my company’s multi-GPU computer, and I’m at my wit’s end. Whenever I start the computer with 5+ GPUs hooked up (we’re trying to use 7), it shuts off before posting. If I plug in 4 GPUs, it worked just fine. I have had it running with 7 cards before, but all of a sudden it started doing this.
(I do have those two 6-pins on the side of the mobo plugged in)
Motherboard: WRX80 Sage II
CPU: Threadripper 5955X
GPUs: Zotac 4090 (7x) (all of the have Gen 3 riser cables)
RAM: G Skill RipJaw 8x 32GB
HD: Samsung EVO Plus 500GB
PSU: Corsair HX1500i Platinum 80 Plus (4x, 1 PSU / 2 cards, and another for a single card plus mobo)
UPS: 4x cyberpower 950W.
Here is what I’ve tried so far with no luck:
I have replaced the motherboard, RAM, CPU, and all the PSUs.
I unplugged each GPU (leaving the other 6 in) and powered it on to test all the PCIe slots, GPUs, and riser cables.
I tried turning the 4 switches on the motherboard on and off in various configurations. Not sure what they do, but it seemed worth a shot.
I updated the BIOS to the newest version
I tried plugging the PSUs directly into the wall to bypass the battery back ups
I tried running the computer from the batteries on the UPS (unplugging the the UPSs from the wall) to rule out the electrical system.
At one point I did manage to get 5 GPUs running, but I wasn’t getting the full power out of the 5th card. 4 cards had a score of ~5600. 5 cards had a score of 6300, which means that 5 card was only delivering about 50% of the power it should have. Now it’s back to only running with 4 or less cards
I’m open to any and all ideas.
