Computer is not responding, went though many tests
            My pc started not showing and sort of live in the display or the beep for booting while turned on. There is no Mobo load screen either. Everything in side the case seems to be on: the fans, CPU cooler, HDD, GPU Fan, and optical drive, just no display. I did do some hardware testing. I tried my GPU on my brothers computer and it worked fine even through some games. I have a old AMD Phenom II 840T, so I replaced my FX-4100 with it and there was no boot to it. I tested the FX on my bro's pc and it booted fine. I even swapped our ram, and my ram worked on his but his did not work in mine.I tested my 7850 on my bro's pc and it also too worked fine. AND I tested my PSU on my bro's pc and vice versa; it was all good.
            I also booted my HDD on my bro's pc too, and that came up strange. I ran the BIOS and set the boot to my HDD instead of his; save the bios and restarted the pc. It went all the way to the windows 7 boot logo and then restarted again and again. It just went through a loop of getting to the windows 7 loading screen to restarting again. So I thought it was a faulty HDD, but then I took my bro's HDD and put it into my pc. no screen just like my HDD. I put his back into his pc and it booted fine. I am soooo confused... any help please?
Sounds like a busted motherboard, have you tried running the board out of your case? along with resetting CMOS?
If you have proved that the RAM,HDD,CPU and GPU along with the PSU all work fine then all thats left is the motherboard. I suspect the HDD didnt like booting on your brothers motherboard due to the fact it doesnt have the driver for his mobo and just crashed (at the logo screen is when drivers etc are loaded usually).
So, take the board out and run it, this should rule out any kind of short between the board and case and also reset the CMOS (bios) this might help sort out any bad settings. Other than that it looks like the board had a fault and needs to be replaced.
Just to be sure, check your monitor is working too, seeing as that could also be the problem :D
ill try running it out of my case... and yes I have done the resetting of the CMOS.... to no avail... IT WOULD REALLY SUCK IF IT WAS MY MOBO CAUSE I ALREADY REPLACED IT... TWICE. DIFFERENT MOBOS EACH TIME... and what should i set my mobo on... i dont have any of the original packaging
ummm anything non conductive, wooden cutting board or glass/plastic.....cardboard etc.
Hey thanks man... did my tests... gues i have to cough up another $150 dollars or so for a new mobo...
Was this happening with the phenom too or just when you put in the new CPU? Because if it's just happening with the new one then you probably just need to update your bios
What model motherboard is it?
What are the specs? You might have some incompatible parts in that build.
you probably need to update the bios for the fx cpu
Yes it was happening to both of them
AsRock 970 extreme3
all my specs are compatible... its not a new build its a year old... just started to not work
No... my bios was up to date... i have had this build for a year now
Main boards is dead. you can try the oven trick to rule out any bad BGA joints. Something similar happened to my old 780i system and cooking it fixed it.
I found a similar problem to that a few times before, and turn out to be that the lithium battery for the bios had become depleted, I replaced the battery and the PCs worked fine.
Not saying is the same problem, but is another thing to try.
its not the cmos battery... that basically keeps the date and time in check when the pc is off...
Yep, the most unlikely culprit is the mobo, but sleuthing is sleuthing: RAM,HDD,CPU and GPU along with the PSU...
I know what it does, DUH. And is not just keeping the clock....
I am telling you that SOME PCs DO NOT TURN ON if it's low.    I didn't understand why, it seem like a very stupid design flaw, but it is something that affects some brands, I have seen it personally in 2 Dell Laptops and 1 HP desktop.
THANKS ALL FOR THE TIPS AND TRICKS NOW... TO CONVINCE THOSE INDIANS TO LET ME RENEW MY WIN7 KEY
lol
