Computer Freezes Randomly With Buzzing Sound
Hello, my computer is encountering an issue that is very rare, but still very annoying. It seems like every couple days and sometimes weeks or so my computer that i built for gaming is freezing up completely. It mostly happens during gaming and the last time it occured was while playing minecraft, which is not a very hard game to run i can imagine. It also happened during Far Cry 3 and other than that it happens pretty rarely but often enough to be annoying. Also when this happens, i can not go into task manager and a buzzing sound comes from my headset. The only thing i can do is restart the computer. One thing to note is that ive noticed my computer is a little dusty but i mostly notice it on top of the power supply. Could this be a cause? Just to give some info, here are my specs:
MoBo: Asus P8Z77-M
CPU: Intel Core i3-3220
GPU: GeForce GTX 650ti Boost
PSU: 500w Corsair builder bronze certified
I would greatly appreciate it if someone helped me fix this issue! Thanks!
overheating i reckon!
Blow out your case with compressed air & see if that helps
ok i think i will try the compressed air. if that does not work i will assume its overheating and i will try to get another fan in the case, because it only has one exhaust fan in it and no fans to cool anything down...
