Computer Case Problems
For the life of me, I can't find a PC Case that can really give me what I need out of it. So can anybody help me find one?
What I need from the case: 1x USB 2.0 and 1x USB 3.0, USBs must be front panel due to my motherboard, and I need some room to fit all my parts, including a Cooler Master Hyper 212 EVO. It also must be $50 or less.
Thank you in advance!
https://pcpartpicker.com/part/nzxt-case-cas220wb1
next... :)
really good quality for $50 btw
I'll add if you want an upgrade, the Fractal Design Blackout R4 with window and Phanteks Enthoo Pro M (which strangely only comes with one fan) but is otherwise very reminiscent of the much more expensive NZXT H440... is at the $30 more mark and I highly recommend both if you're not happy with the budget one
http://www.bitfenix.com/global/en/products/chassis/nova
