Computer Case Fans Important?
I just made a PC with some old parts but mostly new Things like ram motherboard case and power supply. I have a Zalman Z11 Plus Chasis that has 5 fans when i recieved it. I connected all of them of course and my PC booted right up. The only problem is that my fans create so much noise that i cannot hear my videos or music without turning the volume up too loud. Is there a way to turn down my fans beacause my case is freezing anyway....My CPU reads at around 20-35 degrees celcius normally. If i can turn them down what is recommended? Or should I just unplug some of the fans totally?
I got a fan controller for that very reason. I have most of my fans running at 40%, which is doable, but ever since getting a headset, I've never used it. You could get away with as little as two fans, depending on your cooling. If you have a green HDD and/or SSD, and your CPU temps are cool, I'd only just do a bottom filtered intake.
Are the fans plugged into the MB, are they 3 pin or 4 pin?
You can try speedfan and see if you can tame them that way or you can check your BIOS to see it has any fan options. Most newer boards do.
if not.... a resistor inline with the yellow wire would do the trick.... however most people dont like to cut, solder, and heatshrink. :(
wow thts odd because the stock fans on my Z11 plus are pretty quiet. anyways the Z11plus  really only needs like 2 (i would go front intake and rear exhaust but using the bottom intake may work better) you deffinately dont need the two side pannel fans at all and since it comes stock with only one 120mm exhaust on top (it holds 2 140mms) you probably could go without that either. personally i prefer the way the z11 plus looks all lit up and glorious but to each their own. also have you considered buy new fans?
Hey Jerm - what kind of fan controller would you recommend?  I'm running extra case fans to help with my OCing and would love a controller to handle maybe four fans.
Thanks!
Options (not knowing what you're running):
Buy some quiet edition case fans (corsair,noctua, scythe)
Buy Fan resistors
Buy a fan controller
Buy a big heatsink
That last one is there because the loudest fan in the case might be your stock cpu fan, and if you're hitting 30 degrees on stock you could passive cool that sucker no problem.
honestly, most common mondern system can run fine with minimal airflow so feel free to take out some of the unnecessary fans
if you're running a triple or quad sli/crossfire setup then you might want to keep the fans there
I'm personally using the NZXT Sentry, but it's a wee bit clunky. However, it looks nice, it's affordable, and it does the job for up to 5 fans.
i found out that after unplugging all ut 2 of the 5 fans that it ended up being my power supply that is causing the noise...it is a cheap 500w $25 pSU so i think i might save up for a better one like maybe coolermaster or corsair....any cheaper power supplies that are quiet recomended?
SeaSonic do a fanless PSU range, unsure on pricing tho but if silent is what you want, you cant get anything quieter than fanless :P (make sure its a decent brand tho a no-name fanless PSU is likely to be bad)
yes apparently i should have read the reviews on my PSU and it is a no-name brand just "good enough for a normal user" if i had know this i couldve gotton a corsair 500x that i saw there.....Oh well! I guess i COULD go to microcenter and return this PSU, but i don't know if they would take it after ive been running it for a week......
Thanks!
Another thing i noticed after opening my case is that my cpu cooler fan and heatsink is making a loud ticking and buzzing noise....may consider a new one, but are there any good ones that i can put in my foxconn 975x7AA motherboard?
Any 775 socket heatsink should fit, i havnt ever had a foxconn board so id assume its just standard mountings.
Yea its standard I am looking at the Cooler Master Hyper 212 Plus and it looks pretty good...at least better than the one that came with the processor.
yeah thats a pretty sweet heatsink, only heard great reviews on it and its pretty good on price too. Just do the usual and make sure its fits inside your case :)
Yea it should and i found it on amazon for a relitivly low price....
here's the best fanless heatsink i found, just my 2 cence really.
http://quietpc.co.uk/nof-icepipe
